Latest: DanDan17
Overall: 17128
Online Now [66]:
Visitors: 65
Today: 8506
Total: 100569236
Forums › The Car › 206 Problems › 206 GT Clutch sqeal and squeak - Video included
Pd9ph
PostPosted: Thu Oct 25, 2012 3:42 pm Up
Please see video
www.youtube.com/watch?...rIZYMeZdg&
Happened whilst driving tonight, I've noticed a few clutch judders over the past week and not being as smooth going into first or at biting point, then tonight the revs dipped for 2 seconds, clutch went hard then I knew something was up, stopped for a few minutes and could smell what I thought was the clutch. Headed home and parked up for the night.
Think this may be the end of the 206. Just put a new alternator and aux belt on it aswell. I'll price up the parts in the meantime.
Any ideas what it may be. Any assistance would be appreciated!
GTI Grand Tourisme
Gazza
PostPosted: Thu Oct 25, 2012 6:07 pm Up
Are you deffinitly sure thats the clutch as it sounds more like the auxilary belt slipping more than anything, see if the noise come during the day when the alternator isnt on so much load, i've never heard a clutch (thrust bearing ) make that kind of noise before unless it is well and trully dry, i have a good clutch removed out of a gti i broke if its any used to you?
Tripple P\'s......PURE PUG POWER
DeadEyePaul
PostPosted: Fri Oct 26, 2012 2:32 am Up
I had a clutch release bearing wear on mine and the sound doesn't go away its a constant chirp even in neutral it only disappears when pedal is pressed in.
Sounds like a belt as mentioned above. If it is the aux belt if that fails it could get tangled around your drivebelt and break that too
Pd9ph
PostPosted: Fri Oct 26, 2012 2:53 am Up
Well thats a little bit of good news fellas as I ordered an Aux belt yesterday! I'll have a look at the belt after work as I had it off along with the power steering pump when changing the alternator. I've have a look at the belt and it looked a little dried and cracked, but refitted it and re-ordered.
GTI Grand Tourisme
Gazza
PostPosted: Fri Oct 26, 2012 1:08 pm Up
when fitting the new belt make sure you dont over tention it has i will put strain on the pas pump and alternator bearings,
Gazza
PostPosted: Fri Oct 26, 2012 1:09 pm Up
Pd9ph
PostPosted: Sat Oct 27, 2012 4:56 am Up
Cheers mate how do I go about on the tension and tensioning it? I thought the 206 GT auto tensioned itself. This could be down to me not tensioning when I put the old belt back on. Waiting for new belt to be delivered, I suppose it wouldn't do me any harm ordering a new tensioner unit in the meantime and replacing as it squeaked a little before I changed the alternator hence me taking the belt off in the first place. I have a part number the tensioner unit of 5751-61 can anyone confirm? Ill be doing a step by step for members in future with these problems.
GTI Grand Tourisme
dan_manu
PostPosted: Sat Oct 27, 2012 12:13 pm Up
last aux belt i changed i just tensioned so that on the longest point of the belt can be pushed in by around a 1cm with my thumb and its not went yet and that was over a year ago
Pd9ph
PostPosted: Thu Nov 01, 2012 12:43 pm Up
'big' problem tonight heading home, hopefully its related to the belt, (not got round to fitting the new one) Serious problems selecting any gear with alot of clutch judder and clutch pedal shaking? Any ideas? I thought it may be the aux belt slipping and holding up the clutch selection?!
GTI Grand Tourisme
