Posted: Fri Nov 02, 2012 4:04 am |
Sorry if this has been covered, but how much is acceptable? I remember my old GTI using a fair bit but I can't remember how much. I haven't measured this properly but I think I've used about 1 litre in just over 3k.
Car either gets used on the two mile drive to work, or hundreds of miles on the motorway in one go for football.
Any opinions?
| Black 03 GTI. Silver 05 GTI 180 | |
Posted: Fri Nov 02, 2012 6:33 am |
Mine used a bit more than that.
What oil are you putting in?
| - Sinature removed due to size.
Please feel free to upload one of the correct dimensions. | |
Posted: Fri Nov 02, 2012 7:05 am |
Doesnt sound too bad.
Posted: Fri Nov 02, 2012 10:12 am |
180gti is a oil burner
Posted: Fri Nov 02, 2012 6:40 pm |
5w40 semi synth
Posted: Fri Nov 09, 2012 11:48 am |
Mine uses about a litre in 8000 miles.
5/40 fully synth
| GTI 138 facelift - Runabout
335d M Sport - Cruiser | |
Posted: Fri Nov 09, 2012 11:49 am |
Infact scrap that, about half that.
I bought 5 litres to do the change. Used 4.5 on the change and used the rest over the year to top it up. Did about 8k in the year.
Posted: Fri Nov 09, 2012 11:54 am |
mine dont use enough to warrent filling up before the next service think i do 6k a year max atm
Posted: Tue Nov 13, 2012 4:46 am |
what happens if you let the car run with low oil? would the temperature gauge show an increase in engine temperature?
Posted: Tue Nov 13, 2012 4:49 am |
It will probably start to knock rattle if it gets to low. Oil lubricates, water cools.
