Posted: Fri Nov 02, 2012 4:12 pm |
Hey Guys nd Gals!!
As My Topic Title Says.. Im After Some Pics Of Anyones Strut Braces In Their 206??
I Really Want To Get One As From Previous Car Experience I Know They Can Really Make A Difference To The Handling/Feel.. But Im Curious As To How It Fits In & Looks!
Thanks In Advance Peeps!
Posted: Fri Nov 02, 2012 4:40 pm |
You'll be disappointed if you expect to feel a difference on a 206.
Posted: Fri Nov 02, 2012 5:38 pm |
^^ as Edward says. Purely for looks on the 206 due to how the engine is setup on a subframe.
Posted: Fri Nov 02, 2012 5:41 pm |
Engine doesn't sit on a subframe. Lower mount uses the subframe but that's nothing to do with it.
Posted: Fri Nov 02, 2012 5:48 pm |
they just look nice on a 206
| Ford Focus RS in white of course
filled with all sorts of goodies | |
Posted: Fri Nov 02, 2012 6:19 pm |
Edward wrote: |
Engine doesn't sit on a subframe. Lower mount uses the subframe but that's nothing to do with it. |
Apologises I missed a few words. I meant engine bay and how the 206 has a subframe as apposed to other cars like my 106 Rallye which didn't have a subframe and the upper and lower strut braces improved the handling of the car.
Posted: Fri Nov 02, 2012 7:14 pm |
Posted: Fri Nov 02, 2012 7:17 pm |
Posted: Fri Nov 02, 2012 7:22 pm |
There's a few for you also got some when it was white aswell and so you know that's the omp one and fitted to a gti 180 it requires some cutting of the metal on the pollen filter side
Posted: Fri Nov 02, 2012 7:51 pm |
Posted: Sat Nov 03, 2012 4:15 am |
as above they are just astheticaly pleasing 2bh worth £30-£40 ish
Posted: Sat Nov 03, 2012 4:21 am |
Here my pointless modification. Might be of some use if the bar was welded to the car rather than bolted to it using 3mm thick steel.
Posted: Sat Nov 03, 2012 8:23 am |
I Get The Hint That They Might Just Actually Do Nothing Then Guys!!? lol
Cheers For The Feedback.. When I've Got A Few Spare Quid Then I Might Still Get One As From Looking At Everyones Pics They Do Add A Nice Touch To The Bay Cosmetic Wise
Bit of A Pain To Fit By The Sounds Tho
Posted: Sat Nov 03, 2012 8:38 am |
Not on my phone now
When fitting once you have drilled the whole and cut it out grease it or paint it and put a ruber seal around it to stop it rusting that's what I did.
Posted: Sat Nov 03, 2012 10:43 am |
On my old 180..
