Latest: Andyblue64
Overall: 17123
Online Now [411]:
Visitors: 410
Today: 53743
Total: 98140949
Forums › The Car › 206 Problems › Car wont start but makes loud noises and a beep
bisphenol-a
PostPosted: Wed Oct 24, 2012 12:48 am Up
at the turn of the key the car will give the cranking noise for a split second (the usual cranking noise that would be followed by the humming of your engine), problem is after that short moment it comes with a loud noise quite like a machine gun just fired off. really quick succession of noise that sounds like a machine gun or a nail gun firing off. it ends with a beep and the wipers go up and and slowly, lights come back on like when your engine dies.
its a 206cc.
PostPosted: Wed Oct 24, 2012 1:42 am Up
Has your cambelt snapped?!
PostPosted: Wed Oct 24, 2012 2:19 am Up
bisphenol-a wrote:
its a 206cc.
Well thats a start as it narrows it down to a choice of 4 different engines, 3 petrol & 1 diesel.
More info needed if you want help.
Gavin28
PostPosted: Wed Oct 24, 2012 2:36 am Up
could be just a flat battery, the noise you describe sounds like a starter motor relay.
And as MrBSI said, more info is needed about the car
Gav
L5_UKS
PostPosted: Wed Oct 24, 2012 3:45 am Up
Sounds like starter motor to me
bisphenol-a
PostPosted: Wed Oct 24, 2012 4:30 am Up
its a petrol engine 1.6l
i dont want to believe the belt snapped it only travelled 60000 kms not miles and it was just bought 1 month back.
PostPosted: Wed Oct 24, 2012 4:35 am Up
Thats now narrowed the engine choice down to 2 different petrol units Laughing
bezford
PostPosted: Wed Oct 24, 2012 1:41 pm Up
Dont panic!its just the starter solenoid clicking as the voltage in your battery is too low to turn starter over properly,the clicking is the solenoid clicking in and out of its mesh/match up with the flywheel.
When working properly(fully chatged battery)the starter is engaged as you start her,once in place thanks to the solenoid it spins the flywheel,therefore the engine, and starts up the car and as soon as you release the starting position the solenoid then disengages the starter motor,letting the engine run normaly.
The remedy is recharge your battery or test it and get a new battery if its knackered,also with the battery being flat/unwired you will need to perform a BSI soft reboot to get the car to work correctly again once your battery is recharged that is....look for"dillon"on maintenance how toos for the full BSI soft reboot instructions.
R.HYDE
PostPosted: Mon Oct 29, 2012 3:48 pm Up
Any news?
bezford
PostPosted: Tue Oct 30, 2012 4:03 pm Up
Any luck with a good recharge or renewin your battery then bisphenol?
R.HYDE
bisphenol-a
PostPosted: Fri Nov 02, 2012 12:20 pm Up
a new battery was all it needed and problem solved!
$200 but what the heck
