Posted: Fri Nov 02, 2012 5:03 pm |
Driving home in 5th gear yesterday I heard something flick up and hit the bottom of my car. Slowing down for round about a few hundred yards later I went to drop gear and the gear stick was really sloppy and swung from side to side. Could then only select 3rd and 4th for the rest of the journey home.
The anoying thing was my girlfriend actually said while driving my car 30mins or so earlier 'don't blame me if I break your gearbox' (she doesn't like the quickshift) she jynxed it!!
Would this issue be a broken gear linkage? I know it is a common problem but could it be anything else?
Also is there any difference between the size and fittment of gear linkages through out the 206 range? (I'm aware the 180 has a hydraulic gearbox or something).
I'm looking at getting some group n or simillar designed linkages if this is the issue so I don't have a simillar issue again.
Any input would be greatly appreciated as I'm heading over to France, Belgium and holland in 5 weeks an need to get it sorted asap! Thanks in advance!
| | ![](images/spacer.gif) |
| '02 206 Quiksilver. SP Kit. Gloss black 205 Speedlines. ICC Tuning WRC spoiler (civic style). Sparco Rally Flaps. Laguna splitter. Upper and lower front Struts. V-Maxx front coilovers and Apex rear shocks. GTI180 front Arb. GTI180 front brake set up. 4-2-1 Mani, 200cell sport cat, stainless pipes and sportex 3" rolled box. Gloss black morettes with yellow lenses. Yellow tinted fogs with yellow bulbs. | |
Posted: Fri Nov 02, 2012 6:51 pm |
i would have though snap linkage will lost all gear except the one you are in atm
Posted: Fri Nov 02, 2012 7:30 pm |
I can select 3rd and 4th but nothing else. When it was in 3rd or 4th the gear stick could swing from one side of surround to the other or as my friend described it 'like a mixing bowl'
Posted: Fri Nov 02, 2012 7:48 pm |
You checked that its actually snapped? and one hasnt just popped off on one end?
Posted: Fri Nov 02, 2012 7:52 pm |
i think you might have break the selector fork
Posted: Fri Nov 02, 2012 7:53 pm |
LeeThr wrote: |
You checked that its actually snapped? and one hasnt just popped off on one end? |
i always though pop linkage = no gear change anymore.
Posted: Fri Nov 02, 2012 8:24 pm |
Seabook wrote: |
LeeThr wrote: |
i always though pop linkage = no gear change anymore. |
I've had on my 1.4 if the middle linkage popped off I could get 3rd & 4th but nothing else and it went side to side really easily.
Posted: Sat Nov 03, 2012 2:17 am |
I'll be taking a proper look today. What's the best way to find out? Will I need to get under the car?
Posted: Sat Nov 03, 2012 3:07 am |
Yes there is one large rod that goes to the selector system on the gearbox. On the top of the box there are 2 smaller rods (i think from memory). One of those has come off. Thats why it will let you select some gears.
If its popped off then I would get a new one from Peugeot as the nylon in th joint has worn down. Plus it will make your shift a lot better
| 206 180 rally car in progress. I may not be perfect but there are parts of me that are f£%$ing brilliant | |
Posted: Sat Nov 03, 2012 3:26 am |
A common problem indeed.
This is when my already once welded control rod snapped taking away a part of sub-frame's pivot together:
www.206info.co.uk/Foru...tml#559291
In my case it's the control return part #5:
www.206info.co.uk/Foru...tml#559174
In your case -- one of the link brackets #3 might have just split in a half.
Mind you that there are two gearbox systems, the linkages are as follows (could be identified by the shape of (my snapped) part #5):
www.peugeotforums.com/...post2.html
You'll need to get under the car, and remove bottom engine cover.
You might find it is hard to access the link system, as it is blocked by power steering hoses.
Couple of cable ties tied carefully to the side can provide better view.
Good luck!
Posted: Sat Nov 03, 2012 3:54 am |
Thanks for all the help guys. It's lovely out... Cold and wet! I'm sure the fingers will love this!
I sure hope it's only part #3 as it would seem alot easier to replace!
If I get stuck I'll be back!
Posted: Sat Nov 03, 2012 4:44 am |
Just look down from the top, just pull the air intake pipe off and you will have sufficient access.
Posted: Sat Nov 03, 2012 4:50 am |
Its happened twice to me, in the end I bought some stainless steel locking ones from ebay for £50. Sorted the problem!
spike_202 wrote: |
My Powerflow is quite loud but then again it's on ITBs and has a decat. |
Audi Sport ![Cool Cool](images/smiles/icon_cool.gif) | |
Posted: Sat Nov 03, 2012 7:02 am |
All linkages were attached and intact. There was what only I asume to be a bolt missing from one of the pivots that connect to a shaft in the gearbox. I can drive again! May still change the linkages as the gear stick is still a bit sloppy. Gonna change my quickshift to one that sits in the original gear stick housing as I've gone off my alloy race/rally one.
