Latest: DanDan17
Overall: 17128
Online Now [464]:
Visitors: 463
Today: 51091
Total: 100651458
Forums › The Car › 206 Problems › throttle pedal/cable/revs response
bezford
PostPosted: Sun Nov 04, 2012 7:05 pm Up
i have a 2002 206,138gti and to cut a long story short im having a mare of a time sufferin almost a full second between flooring the accelerator pedal and any revs occuring in the engine?ive had old astras and sherpa vans that responded loads better than this so what can i do?ive tried putting adjustment on the engine end of the cable-which worked at first,7mnths ago that is,but no matter where i pin it now it takes an age to respond.
There must be an easy answer/solution to this,i just dont know what just yet?please if you have any ideas or solution please post them here,thanks guys.............i must be losing 2-3 seconds on a 0-60 time having changed gear twice?i know i can ride the throttle if the occasion came up i just prefer not to...cheers.
R.HYDE
PostPosted: Sun Nov 04, 2012 8:34 pm Up
If you press-down the pedal in neutral and then let go, do the revs take a while to drop to idle?
Like they hang-around 2000rpm, before they drop to idle again?
Have you done all service items like sparks, filters etc?
How many miles on the clock?
Do you have a diagnostic (EOBD) of some sort?
bezford
PostPosted: Mon Nov 05, 2012 2:38 pm Up
i will check the pedal later??? as for service it is definately due so that will be done asap......73000mileage and i dont have a diagnostic machine?i will check the web and price one up???failing that the mot is due soon so i will get it checked then.....thanks.. i will respond after i check pedal?
R.HYDE
