Latest: Kifi69
Overall: 17183
Online Now [866]:
Visitors: 865
Today: 25515
Total: 144846178
Forums › The Car › Request a how-to › How to Fit Seatbelt Warning Function
SteDuval1985
PostPosted: Fri Nov 09, 2012 7:54 am Reply with quote Up
How can I install this? What parts do I need?
Saw that Mr BSI had done it in this thread...
www.206info.co.uk/Foru...light.html
PostPosted: Fri Nov 09, 2012 8:00 am Reply with quote Up
You need to see if the 2 pin white connector plug is hidden under the carpet below the drivers seat first before going any further.
You need the buckle with the built in sensor.
You need to tweak the BSI setup configuration.
Also RESPECT for using the SEARCH Thumb Up
iainlovatt
PostPosted: Fri Nov 09, 2012 8:02 am Reply with quote Up
I had mine disabled, it did my head in, but a query with regards to this, can you make it so the passenger one works, does anyone know if the loom is there? it is as far as the seat goes, but i have always wondered if there is one under the carpet.
(My Garage)
PostPosted: Fri Nov 09, 2012 8:05 am Reply with quote Up
Wasnt in my 2003 vintage 206, just the side airbag loom hidden under the carpet below the passenger seat.
Side airbags & seat belt warning where both easy retrofits for me Cool
SteDuval1985
PostPosted: Fri Nov 09, 2012 8:07 am Reply with quote Up
Did you have to remove the seat to check?
iainlovatt
PostPosted: Fri Nov 09, 2012 10:51 am Reply with quote Up
Of course unless you have the smallest hands in the world and can twist them in multiple angles, Smile
(My Garage)
PostPosted: Fri Nov 09, 2012 5:10 pm Reply with quote Up
How else are you going to get under the carpet to play hunt the wiring loom? Laughing
  Quick Reply
Username:
Message:
Quote the last message
