Posted: Fri Nov 09, 2012 7:54 am |
Posted: Fri Nov 09, 2012 8:00 am |
You need to see if the 2 pin white connector plug is hidden under the carpet below the drivers seat first before going any further.
You need the buckle with the built in sensor.
You need to tweak the BSI setup configuration.
Also RESPECT for using the SEARCH
Posted: Fri Nov 09, 2012 8:02 am |
I had mine disabled, it did my head in, but a query with regards to this, can you make it so the passenger one works, does anyone know if the loom is there? it is as far as the seat goes, but i have always wondered if there is one under the carpet.
Posted: Fri Nov 09, 2012 8:05 am |
iainlovatt wrote: |
I had mine disabled, it did my head in, but a query with regards to this, can you make it so the passenger one works, does anyone know if the loom is there? it is as far as the seat goes, but i have always wondered if there is one under the carpet. |
Wasnt in my 2003 vintage 206, just the side airbag loom hidden under the carpet below the passenger seat.
Side airbags & seat belt warning where both easy retrofits for me
Posted: Fri Nov 09, 2012 8:07 am |
MrBSI wrote: |
Also RESPECT for using the SEARCH |
Did you have to remove the seat to check?
Posted: Fri Nov 09, 2012 10:51 am |
Of course unless you have the smallest hands in the world and can twist them in multiple angles,
Posted: Fri Nov 09, 2012 5:10 pm |
SteDuval1985 wrote: |
MrBSI wrote: |
Did you have to remove the seat to check? |
How else are you going to get under the carpet to play hunt the wiring loom?
