Latest: heikkisj
Overall: 17126
Online Now [52]:
Visitors: 51
Today: 956
Total: 100334005
Forums › The Car › 206 Problems › 1.6 hdi oil leak:(
1.6 hdi oil leak:(
simonster_14
PostPosted: Sat Nov 10, 2012 1:10 pm Up
alright everyone?
just replaced the oil pump, pick up and crank seal on the dv6ted4 engine which has solved the last issue of low oil pressure:D
but it has left me with an oil leak right under the exhaust/cat where there is no bolt for about 5-6inches on the sump, also when i removed the sump i noticed there was no sump gasket, which is pretty confusing when the engine face is dead flat but the sump has raised parts?
i know you can buy gasket paper or sheets of cork to make a gasket from but cant imagine it being that simple?
does anyone know of anyone who makes gaskets for the engine as some sort of upgrade?
cheers guys
richpowell91
PostPosted: Sat Nov 10, 2012 1:14 pm Up
Ive always used Wurth RTV silicone sealer without fail on many sumps.
simonster_14
PostPosted: Sun Nov 11, 2012 5:12 am Up
might look for some of that then,
i used some "blue" silicone based sealer that came in a yellow tube and is white in colour...obviously that isnt working for me
thanks for the advice
