Latest: sparrowdclxvi
Overall: 17139
Online Now [128]:
Visitors: 127
Today: 15279
Total: 113020910
Forums › The Car › 206 Problems › Entering the radio code
SteveTDCi
PostPosted: Fri Nov 16, 2012 1:59 pm Up
How do you enter the radio code, the code on mine s allegedly 9519 using numbers 1 -6 I can work out, so either I need to work out how to enter a 9 or someone has written the code down wrong. Any ideas ?
206 1.4 LX ... its called Vera and is built for abuse, but needs a few things, including hoovering out
iainlovatt
PostPosted: Fri Nov 16, 2012 2:01 pm Up
code is wrong! Sad
(My Garage)
SteveTDCi
PostPosted: Fri Nov 16, 2012 2:21 pm Up
I thought that might be the case. Looks like I need to go through the books.
SteveTDCi
PostPosted: Fri Nov 16, 2012 2:49 pm Up
Yay, found it. It was on the original sales invoice from 1999 Smile
bezford
PostPosted: Fri Nov 16, 2012 6:14 pm Up
Stop......the code isnt wrong its how u enter it that is the key here....on your radio you have six buttons 1to 6 that are your radio presets but also for code entry....just leave your radio untouched for as long as possible(because entering wrong codes doubles the time u must wait before u can try again properly)
then take the codes first number and tap this number into the radios number 1radio preset button(or tap button 1_9times.then button 2_5 times.then button 3_1time.then button 4_9 times....just ignore theother two buttons)this should fix it...
R.HYDE
