Latest: DanDan17
Overall: 17128
Online Now [52]:
Visitors: 51
Today: 10667
Total: 100571387
Forums › The Car › 206 Talk › Are the brakes any good?
Tolkienfan001
PostPosted: Sun Nov 11, 2012 9:03 am Up
Trade Rating: +13
www.mtecbrakes.co.uk/i...6irl5jikg6
Can someone who knows something about discs and pads etc have a look at the above link and let me know what you think?
2005 1.4 16v Sport
Check out my 206 here!
PostPosted: Sun Nov 11, 2012 9:09 am Up
£55.30 for Pagid discs and pads at Euro Car Parts with the Pagid30 discount code.
Tolkienfan001
PostPosted: Sun Nov 11, 2012 10:09 am Up
Trade Rating: +13
Have you got a link? I can't find it??
2005 1.4 16v Sport
Does this go for their ceramic anti-squeal grease paste?
If so I need to get some.. it's the only stuff that keeps on working after 2-3 months.
PostPosted: Sun Nov 11, 2012 10:37 am Up
You can't find Euro Car Parts?
Tolkienfan001
PostPosted: Sun Nov 11, 2012 11:50 am Up
Trade Rating: +13
I can find euro car parts just not the discs and pads set. Do you buy them separately?
2005 1.4 16v Sport
PostPosted: Mon Nov 12, 2012 6:12 am Up
Just put your reg number in then seach for pads and then discs.
bezford
PostPosted: Mon Nov 12, 2012 2:38 pm Up
is copper grease still used?
R.HYDE
Dillon
PostPosted: Mon Nov 12, 2012 2:58 pm Up
Staff - Dillon
Yes I still use it Razz
PostPosted: Mon Nov 12, 2012 3:05 pm Up
On the backs of pads & caliper mating surfaces = YES
On slide pins = NO as copper grease damages the rubber dust seals, use the correct brake grease on these!
PostPosted: Mon Nov 12, 2012 3:07 pm Up
Yep. Was using this at the back of pads for years.
However in this application it stops working after a while..
I then tried Pagid ceramic paste and they've gone silent for the past 2.5 years and counting.
'Copper-ease' is still brilliant for lots of other uses though.
Tolkienfan001
PostPosted: Wed Nov 14, 2012 7:22 am Up
Trade Rating: +13
Thank you for your help I appreciate it!
2005 1.4 16v Sport
