Latest: dreyfalon
Overall: 17121
Online Now [503]:
Visitors: 502
Today: 46785
Total: 97450532
Forums › The Car › 206 Problems › Spare wheel cage
Spare wheel cage
stonster
PostPosted: Sun Nov 18, 2012 8:35 am Up
I'm sure this has been answered before... but I couldn't find it! Can you fit a normal size wheel/tyre in the spare wheel cage? I'm fed up with the space saver... I'm on 14" wheels but I do have a towbar fitted. Anyone done it?
stonster
PostPosted: Sun Nov 18, 2012 8:37 am Up
yes. normal 15" alloy no problem at all
stonster
PostPosted: Sun Nov 18, 2012 9:02 am Up
Thanks, does the jack still fit in? And does it sit lower, snd risk scraping on stuff at all?
stonster
PostPosted: Sun Nov 18, 2012 9:05 am Up
you have to lower the cage a bit but it won't scrap.
PostPosted: Sun Nov 18, 2012 9:11 am Up
Just stick the wheel in the boot. Keeps in better condition like that.
stonster
PostPosted: Wed Nov 27, 2013 6:38 am Up
I can confirm this works with a 14" and with a towbar as well and you can fit the jack in
stonster
