Trade Rating: +16
has anyone moved there's along with the cable? im havig to remove my airbox its bolted on there so need to put it somewhere else, where else can i put it? does it matter?
Posted: Sun Nov 18, 2012 2:00 pm
any where will be fine but you will might have to adjust the cable accordingly
the easily place will be on the battery box (if you have one)
make sure you bolt it tight and nothing will be caught by the cable
anton1989
Posted: Sun Nov 18, 2012 3:05 pm
Trade Rating: +16
funny you should say that i was thinking the battery box as it is the only thing there really unless i had a bracket made.
just realised i have lost the little part the cabe screw into
Interactive software released under GNU GPL,
Code Credits,
Privacy Policy
