Posted: Sat Sep 29, 2012 1:22 pm |
Posted: Sat Sep 29, 2012 4:59 pm |
why is the back end so high up?
| Ford Focus RS in white of course
filled with all sorts of goodies | |
Posted: Wed Oct 17, 2012 2:38 pm |
Posted: Fri Oct 26, 2012 1:58 pm |
got a bit more done today no pics mind you, but went to garage to have brakes looked out and car checked over in general. Need rear shoes, driver rear brake cylinder plus a drum for driver side to after this was all done brake are good again thankfully everything else on the car is tidy from looking at it from it being on the 4 poster, only 2 issues to sort leaking pas fluid from the front somewhere and split cv boot.
Plans once all done will be to get it lowered and nimords back on
Posted: Sat Nov 10, 2012 7:21 am |
Car had some water thrown over it to clear some much, also managed to change to some standard rear lights. Need to sort a few things as mentioned previously driver side outer cv boot, pas fluid leak, centre console display being the main things probably around christmas or new year I'll get the manifold on custom 2.25" manifold back system with a spoon n1 style backbox.
Probably get cracking making the inlet and vacuum box for the throttle bodies over the next few weeks being well, saving the pennies for all this stuff plus lowering is fun :S
