Posted: Wed Oct 31, 2012 5:41 am |
Hi,
Sorry if this has been covered before, I have tried to do a search on the problem. I have a 1999 206 GLX 4 door 1.4, it has a two button remote key.
When the button is pressed to lock the car all doors lock and immediately unlock. I have sat in car and pushed lock down and same happens.
I have tried resetting the buttons as described and also re sync with the bsi all to no avail.
Is there one of the locks which is the master and controls all the others that could be faulty or could somebody suggest a answer.
All suggestions gratefully received.
Steve
Posted: Wed Oct 31, 2012 5:58 am |
Try to identify the side which is malfunction. Spray some wd-40 into the lock first, it might solve your problem if your lucky. If still not working you will need to replace the door lock solenoid.
Posted: Wed Oct 31, 2012 6:07 am |
But could you advise which one needs replacing
Posted: Wed Oct 31, 2012 6:13 am |
LORDPSK wrote: |
But could you advise which one needs replacing |
can you tell me how long this piece of string is that im holding ?
no , because there's no such thing as psychic powers
Posted: Wed Oct 31, 2012 6:33 am |
cartoonhead wrote: |
can you tell me how long this piece of string is that im holding ? |
7 and 3/8 inches.
Posted: Wed Oct 31, 2012 6:38 am |
Checked all the doors are fully closed? I've had the same when a rear door wasn't shut properly.
Posted: Wed Oct 31, 2012 7:00 am |
All doors are closed, no interior light on, sprayed all doors locks with wd40, interior light comes when drivers door is opened but not when passenger front door is opened, so considering that the door light switch is part of the door lock would I be right in thinking I should try that lock.
Posted: Wed Oct 31, 2012 7:39 am |
i think either one of your door locks has burnt out and needs replacing or you need to do what i done and pay 150quid to get a new central locking system haha
Posted: Wed Oct 31, 2012 10:07 am |
dan_manu wrote: |
i think either one of your door locks has burnt out and needs replacing or you need to do what i done and pay 150quid to get a new central locking system haha |
Locks are dead-cheap on eBay.
What do you mean central locking system?
Posted: Wed Oct 31, 2012 10:18 am |
i took mine to the garage like 4 months ago and complaining of the same problem and i had to get my whole central locking re done by a peugeot specialist and it cost me 150quid! i cant remember what he said was wrong with it but it was the worst case scenario haha just my luck
Posted: Wed Oct 31, 2012 10:30 am |
dan_manu wrote: |
i took mine to the garage like 4 months ago and complaining of the same problem and i had to get my whole central locking re done by a peugeot specialist and it cost me 150quid! i cant remember what he said was wrong with it but it was the worst case scenario haha just my luck |
You really mean they hadnt got a clue how to diagnose the fault correctly so they just replaced all the lock motors at your expense
Posted: Wed Oct 31, 2012 11:37 am |
LORDPSK wrote: |
All doors are closed, no interior light on, sprayed all doors locks with wd40, interior light comes when drivers door is opened but not when passenger front door is opened, so considering that the door light switch is part of the door lock would I be right in thinking I should try that lock. |
Good thinking,start from there
Posted: Wed Oct 31, 2012 12:06 pm |
yeah probably! wouldnt be suprised
Posted: Thu Nov 01, 2012 9:08 am |
Right, had a relook at locks with windows down and doors closed to carry out tests, each door on its own.
1. Push drivers door button down locks all doors and then unlocks immediately,
2. Front passenger door, button down, stays down, does not activate any other door locks. Same thing happens using key in passenger door lock.
3. Rear doors, push button down, stays down, does not activate any other door locks.
4. Remote fob (two button type) , same result as drivers door.
Conclusion or further tests to be done, open to suggestions please,
Steve
Posted: Wed Nov 21, 2012 6:40 am |
change the driver's lock
