Posted: Thu Nov 22, 2012 6:33 pm |
Ok getting out the car earlier and the wind whipped the door open
It made a nasty sounding bang as it stopped
Luckily the door didn't hit the wing so no damage done there
Only problem now is the door doesn't shut as it did
I can still close it but really have to slam it
When I push the door it doesn't close it stops short
I've not been able to have a good look at it yet as it's been too dark
But any ideas what might have bent/broken??
| | ![](images/spacer.gif) |
| Yes I own a CC and I'm neither gay or a hairdresser!! | |
Posted: Thu Nov 22, 2012 6:55 pm |
Hinges have dropped lift the door up from the bottom till it meets that catch correctly.
| Image removed due to size
focus st 3 with pro alloy intercooler, 3" mongoose down pipe, 200 cell sports cat and mongoose cat back, collins bov, dreamscience dsci cold air intake,focus rs injectors,focus rs oil cooler,dreamscience dsci tuneing platform mod X map,focus rs clutch & flywheel, rs fuel pump, polly bushes in wish bones rear axal and suspension white line front and rear arb, eibach pro street s suspension. | |
Posted: Fri Nov 23, 2012 2:56 am |
I feel your pain, a bin flew down the road and smashed straight into my old vts last time it was really windy
You might be able to slacken off the hinges slightly and lift the door a bit till it lines up, 2 people are easiest for this so one can keep it where it needs to be and the other tighten the hinge back up.
Posted: Fri Nov 23, 2012 11:44 am |
Well managed to have a look today at work during my break
It seems that the door is to high,it's catching right at the front
where the plastic mirror surround is and the window doesn't go back into
the rubber channel correctly but I can lower the window a bit then put it back up and it goes in fine
Could this be a hinge problem??
Posted: Sat Nov 24, 2012 10:39 am |
Any body got any ideas??
Posted: Sat Nov 24, 2012 2:33 pm |
I've done this before on a 206, I never found out what it was though.
Posted: Sat Nov 24, 2012 3:33 pm |
well all the manufactures do when assembling the cars if a door isnt sitting correctly they wack it into place with a soft mallet
