Posted: Thu Nov 22, 2012 12:46 pm |
Posted: Thu Nov 22, 2012 1:16 pm |
What makes you think there faulty?
Posted: Thu Nov 22, 2012 1:21 pm |
goes on three cylinders when warms
I get P0300 code, and spark plugs are OK (checked)
any other reason to be on 3 cyl?
Posted: Thu Nov 22, 2012 1:22 pm |
injectors..
Posted: Thu Nov 22, 2012 1:36 pm |
Might be, but P0300 seems a ignition failure, and the mechanic thinks it's not injectors thing...
I may open another topic regarding the problem, but at the moment I would like to check if it's ignition coils, so any info regarding the compatibility issue would be great.
Posted: Thu Nov 22, 2012 5:22 pm |
kernel wrote: |
I may open another topic regarding the problem, but at the moment I would like to check if it's ignition coils, so any info regarding the compatibility issue would be great. |
That code is a very generic code, I've had it several times before now, it's been coil pack and injectors.
As for using another coil, im 99.9% certain the 180 run's a different pack to the 138.
Posted: Fri Nov 23, 2012 8:42 am |
any easy way to check injectors?
the problems appears after 2 minutes of warming up.
It doesn't appear with the car on Idle.
