Latest: heikkisj
Overall: 17126
Online Now [60]:
Visitors: 59
Today: 18451
Total: 100391148
Forums › The Car › 206 Problems › BSI swap
BSI swap
levelboss1065
PostPosted: Sat Nov 24, 2012 5:28 am Up
are these interchangeable. ie can i get one from the scrappy and simply swap over or is some daft coding required?
PostPosted: Sat Nov 24, 2012 8:11 am Up
Daft coding required.
Better to replace ECU/BSI + key.
Deano
PostPosted: Mon Nov 26, 2012 2:29 am Up
Then that will mean ignitin petrol cap, door looks, boot lock wont it ?
PostPosted: Mon Nov 26, 2012 4:28 am Up
You only need the electronics from the key, so you can swap the blade over to keep the original locks.
I think making the note of the VIN from the donor car is advantageous for future use.
PostPosted: Mon Nov 26, 2012 1:30 pm Up
Absolutely, and any half-decent supplier does this.
