Latest: Kifi69
Overall: 17183
Online Now [374]:
Visitors: 373
Today: 24965
Total: 143573704
Forums › The Car › 206 Problems › Name that part??
Name that part??
Mounty
PostPosted: Fri Nov 30, 2012 1:00 pm Up
Small part broken off from end of driveshaft where it fits into hub.
Its a approx 2.5-3" ring with teeth all the way round the outer edge. Tucks in behind wheel bearing I think. 1 part of it had fallen out in garage and the rest of it just pulled out. Looks as if it maybe had a seal attached to it when it was new?
Just need to know what its called so can get a replacement. Should there be a cir clip to hold it on?
2001 206 Gti - Original & Unmolested
1994 Renault 5 - Production Car Trials
lmilligan
PostPosted: Fri Nov 30, 2012 1:10 pm Up
think your describing the ABS sensor
cartoonhead
PostPosted: Fri Nov 30, 2012 1:14 pm Up
ABS sensor ring if it looks like THIS
Mounty
PostPosted: Fri Nov 30, 2012 1:37 pm Up
Good work chaps, that looks like the bit. Will that just tap on to the end of the drive shaft then? Wondering if there is a seal missing from end of shaft as when I pulled it off had a very perished bit of rubber stuck to it?
EDIT: Just seen a Youtube vid, looks like a little heat will sort it!!
Mounty
PostPosted: Sun Dec 02, 2012 2:49 pm Up
Got one coming off Fleabay. Prices vary from £2.50 - £30.00 so went somewhere in the middle for a hardened one. Local Pug dealer hadn't a clue which part i was on about but when they eventually did said part is no longer available, you have to buy it on a replacement drive shaft!! Shocked Ooosh!!
