Latest: Flyin180
Overall: 17116
Online Now [27]:
Visitors: 26
Today: 10677
Total: 95028784
Forums › The Car › 206 Talk › Whats that screw? Near the throttle in the Engine?
NayNay1991x
PostPosted: Tue Dec 04, 2012 12:51 pm Up
I see a star shaped screw I personally think its an adjuster for the limit of amount of throttle its like one of them Star shaped ones. Its on the throttle lever where you can push it with your thumb.
Just wondering the size of the Tool i would need as there's loads of different sized in halfords, Looked in the Haynes manual and online but can't seem to find anything.
LiamGTi180
PostPosted: Tue Dec 04, 2012 1:20 pm Up
Buy a set of Torx bits. If its small try a set with T5 - T40 and that should cover it
PostPosted: Tue Dec 04, 2012 1:32 pm Up
It's a "Don't touch it if you have no idea what it does" screw. You find quite a few of them all over the car Laughing
A picture might help. It might be an adjuster to stop the lever going too far back, so adjusting it might reduce the idle speed, on the other hand, it might let the throttle open more, a bit of a poor mans speed limiter.
kizza93
PostPosted: Tue Dec 04, 2012 2:15 pm Up
i think it is the idle controll tighteng it will make the car rev a bit more lossening it will have the oppisite effect
