Latest: heikkisj
Overall: 17126
Online Now [50]:
Visitors: 49
Today: 3836
Total: 100313262
Forums › The Car › 206 Problems › 2.0 hdi d turbo no power
swaynie
PostPosted: Mon Jun 25, 2012 3:56 pm Up
Ive only had my car a couple of days so I took her out for a blast today and im very underwhelmed i put my foot down expecting something and nothing the car struggles to rev past 3k and has some torque low down buit nothing up top and the car struggles to get to 60-70mph Sad
If your offended by my posts call\r\n0800 I dont care Wink
PostPosted: Mon Jun 25, 2012 4:07 pm Up
Limp mode?
swaynie
PostPosted: Mon Jun 25, 2012 4:17 pm Up
there are no lights on the dash
PostPosted: Mon Jun 25, 2012 4:18 pm Up
3000rpm is limp mode.
turbo is above 2000rpm.
i would have though 3000rpm is more than enough for 70mph
swaynie
PostPosted: Mon Jun 25, 2012 4:20 pm Up
what would cause limp home mode as i dont have the engine management warning light on?
PostPosted: Mon Jun 25, 2012 4:26 pm Up
is you light working?
need to get it code read
Aar_Im_A_Pirate
PostPosted: Mon Jun 25, 2012 5:09 pm Up
Might be fuelling issues - fuel rail pressure?
Team: Derv
swaynie
PostPosted: Mon Jun 25, 2012 6:20 pm Up
all the dash lights work after a few hours bashing google I think im going to clean the egr and look for boost leaks as i can hear the turbo spooling and check the fpr aswel
hayes_ctfc
PostPosted: Tue Jun 26, 2012 5:51 am Up
When I bought my DTurbo, it was sluggish, I had the EGR Valve flushed and cleaned, and from then on it's been fine, and that was new years day I had it flushed and been fine since. Only been inot limp mode once becuase of an air flow meter fault, but got a new AFM and it's perfect!
OLD: Peugeot 206 2.0 GTi 138
NEW: Seat Leon FR TDi 170
swaynie
PostPosted: Tue Jun 26, 2012 2:47 pm Up
Did you take the egr off
hayes_ctfc
PostPosted: Tue Jun 26, 2012 4:23 pm Up
I didn't do it myself, my dads mate did it at his place as my work was closed new years day, I dunno what he did but he said he flushed it and cleaned it and it's been fine since
swaynie
PostPosted: Thu Jun 28, 2012 3:55 am Up
I've taken the vacuum hose off the egr to give a little more power and no change so I think I have a boost leak, are there any problem areas in the boost system to look for
hayes_ctfc
PostPosted: Thu Jun 28, 2012 9:11 am Up
Just found this on your chassis number under turbo diagnostics on service box:
INFO’FLASH
058W00U1 : Version 0 of 29/06/2000
FOR : 206 AND TURBO DIESEL DW10TD
CUSTOMER SYMPTOM : The engine lacks power ; Noise at the air intake, whistling of the turbo
CONDITIONS IN WHICH FAULT APPEARS : On acceleration
1. ORIGIN
Disconnection of the sleeve between the turbo and the rigid intake pipe.
2. AFTER-SALES REPAIR
Replace the sleeve .
Remove the rigid intake pipe .
Degrease the turbo and the intake pipe.
Refit the assembly , aligning it carefully.
Replace the clamp securing the sleeve on the turbo with a spring clip (Part number 0382.H6).
Make out a cri for each case encountered.
3. PRODUCTION SOLUTION
for 206 : Being studied.
406 From build code 847089 : Fitting of new collar with spring reserve .
hayes_ctfc
PostPosted: Thu Jun 28, 2012 9:13 am Up
If that is the problem, the hose clip (382H6) is short of £2 from dealers so nothing on money really, from your descriptions this does sound like the solution
Edit: Roughly 0.80 of an hour labour time
swaynie
PostPosted: Thu Jun 28, 2012 4:39 pm Up
I've read the description is this pipe for a recirc dv? Or do you have a pic of the offending pipe thanks
Edit
I've read your description again so it's just a clip is this on the boost side of the turbo
