Latest: heikkisj
Overall: 17126
Online Now [56]:
Visitors: 55
Today: 5987
Total: 100339020
Forums › The Car › 206 Problems › unwanted lowering!!!
anton1989
PostPosted: Fri Dec 21, 2012 4:59 pm Up
Trade Rating: +16
so then, got in my car to go home after work today and the car would not move. thought my brakes were stuck till i saw this!
spring had snapped and dug into my tyre!!!
all i need before christmas
very wierd as just 2.5 hours before i had used it on my lunch to go to subway and all was fine?
thank god it didn't happen on the m6 on the way home!
car is not lowered either Shocked
20Drift
PostPosted: Fri Dec 21, 2012 5:11 pm Up
Jesus! Never seen that happen before. Was there any rusting/corrosion on the springs that you noticed?
anton1989
PostPosted: Fri Dec 21, 2012 5:38 pm Up
Trade Rating: +16
not really had a look but from the pictures they are not that bad?
20Drift
PostPosted: Fri Dec 21, 2012 6:17 pm Up
I meant did you notice any before it collapsed onto the tyre. It doesn't look bad in the picture though. I guess it's a good excuse to upgrade to some Bilsteins Wink
DanT
PostPosted: Fri Dec 21, 2012 7:50 pm Up
See this a lot more these days. State of the roads round here springs snap on all sorts of cars. Modified or standard. Happened to me on my old saxo vts about 2 days after i bought it. When i took it all apart the other side had been replaced already.
anton1989
PostPosted: Sat Dec 22, 2012 1:34 am Up
Trade Rating: +16
O, no I didn't mate. Its not that bad, easy fix but all fell on to my tyre stopping it from moving, had this happend on the motorway on my way home It would have been seruious. Worries me thinking about. Just a pain in the a**e because the car is for sale soon and I didn't want to spend any money on it.
Yeah the roads near me are very bad I have hit a few deep pot holes since moving and thought my wheel was f****d had to have tracking done a few time aswell
stevesey
PostPosted: Sat Dec 22, 2012 7:11 am Up
Spring failures are common these days - combination of speed bumps, manufacturing tolerances and the fact that cars just last longer.
Wife lost a tyre on here Corsa because the end of the spring was just brushing the tyre one full lock - so she drove a few 100 yards before the noise and smell altered her.
Strange thing is they nearly always seem to go when stationary, or the instant you move off after a halt. I've seen lots of posts on various forums about broken springs - not one occurred when moving.
PostPosted: Sat Dec 22, 2012 7:53 am Up
That's not a GTi is it? I've got some near pristine GTi springs that were removed from the car in 2004.
Cold weather also makes the springs brittle.
bezford
PostPosted: Sat Dec 22, 2012 9:16 am Up
Could have been bad...lucky id say...new springs in the fkautomotive site just £20 if i remember rightly.
.just go on site.look in the green sale/bargain box under pug 206 and u will see them...struts for under tenner aswell...
R.HYDE
anton1989
PostPosted: Sat Dec 22, 2012 1:00 pm Up
Trade Rating: +16
thanks mate
Edward its a 2.0 hdi thing the spring would still fit? i have som coilovers to use for now. cant afford anything before chrismas
PostPosted: Sat Dec 22, 2012 4:20 pm Up
GTi spring would fit yes. GTi and HDi 2.0 use the same front damper.
gaffa786
PostPosted: Sat Dec 22, 2012 4:46 pm Up
damn that is crazy lucky you wearnt driving would have been dangerous
PostPosted: Sat Dec 22, 2012 10:19 pm Up
Cold causes this no problem.
Is it cold over there at the moment?
PostPosted: Sun Dec 23, 2012 10:47 am Up
Its our roads and the weather to blame.
Replace both though, never one
pnut_man
PostPosted: Sun Dec 23, 2012 12:00 pm Up
That is some seriously scary stuff! i got some 50mm springs if ya want them too.
