Posted: Sun Dec 23, 2012 10:02 am |
somtimes my car wont start up and when it does it appears to have a missfire, took it to the garage and it came up on the machine as having a random missfire fault which is caused by the coil pack. ive had a look at prices on euro car parts and the prices vary from £35 to £70. which coil pack should i go for? and ill need to replace the plugs with bosch super 4. cheers
| | ![](images/spacer.gif) |
Posted: Sun Dec 23, 2012 10:38 am |
Get a genuine bugicord pack from the main dealer about £60
Posted: Sun Dec 23, 2012 11:18 am |
alright mate cheers, looked at the plugs that are currently in the car and there ngk, which im guessing thats whats caused the fault
Posted: Sun Dec 23, 2012 3:24 pm |
I would change the plugs for non NGK first before buying a coil pack, if you buy a secondhand coil pack then drive the car to the breakers to try ASAP you buy as there are many damaged secondhand coil packs out there
