Posted: Mon Jan 21, 2013 4:57 pm |
hey everyone i have a 99'' gti the handbrake does about 11 clicks but only hardly works i had a new axle not long back so i think it may need adjusting as the pads are ok. can this be done on the handbrake it self underneath?
cheers
Posted: Mon Jan 21, 2013 5:21 pm |
Yep just tighten the bolt under the handle.
Posted: Mon Jan 21, 2013 5:22 pm |
oh very good cheers buddy
Posted: Mon Jan 21, 2013 5:41 pm |
Posted: Mon Jan 21, 2013 5:44 pm |
cheers p6raf thats ace
Posted: Tue Jan 22, 2013 3:57 am |
Easy job mate, took me 5 mins the other day... Remove torx screw (T20) at back of handbrake surround. Then you should see a long screw thread and nut. Use a 13mm deep socket or 13mm spammer to adjust. Be careful not to adjust too much cause the nut will go off the end of the thread.
Posted: Tue Jan 22, 2013 4:54 am |
Or don't tighten it too much like I did and snap the cable!!
| 1997 106, 2002 206 LX 1.4, 2004 GTHDI,
2008 207 GT, Renault Clio 1.4 Dynamique 2006,
Honda Civic Type R 2004 EP3 Model and a road legal Suzuki LTZ250 Quad Bike
Old Registration Info, Over 2000 Posts
13 Seller Feedbacks | |
Posted: Tue Jan 22, 2013 8:55 am |
Not essential but should be common practice, jack it up to make sure the wheels still rotate freely.
