Posted: Thu Jan 03, 2013 12:41 pm |
does a gt front bumper need sports wings to fit? or would it fit with normal non sport wings?
thanks dan
Posted: Thu Jan 03, 2013 12:46 pm |
No it doesnt, you might find the arch liners a bit tight though.
Posted: Thu Jan 03, 2013 12:50 pm |
phew! it came with inside arch covers also , thsnk you very much for your help
Posted: Thu Jan 03, 2013 12:55 pm |
GT bumper was never fitted to sports wing when it appeared on a 206 from the factory.
Posted: Thu Jan 03, 2013 12:57 pm |
ahh right so what were gt wings like then? non flared?
Posted: Thu Jan 03, 2013 12:59 pm |
Normal wings with little arch trims on them - not normal SP arches.
Posted: Thu Jan 03, 2013 1:00 pm |
ahh so il be fine then, thanks for you info , much appreciated
Posted: Thu Jan 03, 2013 2:50 pm |
And your only allowed to fit them if you are going to rally your car
Posted: Thu Jan 03, 2013 2:51 pm |
rally it round maccies car park
Posted: Thu Jan 03, 2013 2:58 pm |
only if you do the drivethru at over 40mph
Posted: Thu Jan 03, 2013 3:12 pm |
arch liners will fit fine as gt's had non sport wings the same as your car
