Posted: Sun Jan 06, 2013 1:15 pm |
hi all i am puttin a 306 d turbo engine in my car what is a dw8 206 i am useing dw8 gearbox and shafts but what clutch shall i buy a 206 dw8 1 0r a 306 d turbo 1 cheers
Posted: Sun Jan 06, 2013 6:01 pm |
Please let us know how this goes it was something I always wanted to do. Tricky answer, might it be worth getting both from somewhere online like carparts4less then you can send the wrong one back via the distance selling regulations.
| 206 1.9D, 210,000 now dead following failed submarine experiment (flood) | |
Posted: Mon Jan 07, 2013 5:30 am |
I would reckon on it needing the gearboxs clutch to match the input shafts size and fitting...its just the flat face of the flywheel that the clutch meshs with on the engine size...that and the bolts???if your parts supplier has both in stock have a good compare and see if the bolt holes match up...if they match get the 206one.
Posted: Mon Jan 07, 2013 11:39 am |
cheers guys
| 206 5 door black cyclones tinted back windows | |
