Online Now [208]:
Visitors: 207
Today: 31938
Total: 142938049
Forums › The Car › 206 Talk › cold air feed pipe
cold air feed pipe
dan_manu
PostPosted: Sun Jan 06, 2013 4:19 pm Up
does this look ok?
www.ebay.co.uk/itm/251...1423.l2649
as my car came with a chavvy cone filter, advice and help appreciated
jk206
PostPosted: Sun Jan 06, 2013 4:33 pm Up
looks abit thin so it might split easy but thats what you get for the price i suppose.
dan_manu
PostPosted: Sun Jan 06, 2013 4:37 pm Up
yeah its cheap but they all do the same job , so dont realy want to spend loads
would it be long enough to go from cone to bumper yeah? and you can connect them to the cone yeah?
jk206
PostPosted: Sun Jan 06, 2013 4:52 pm Up
should be long enough but then again i dont know where abouts your curent filter is in the bay, i dont think you connect them to the cone i recon the end of the cold feed is postioned next to the cone
DanT
PostPosted: Sun Jan 06, 2013 4:54 pm Up
Ive used some in the past that i got from Kam Racing which was decent, didnt look amazing but worked well and was pretty strong.
www.kamracing.co.uk/un...cting.html
Thats what it was, if you work out the diameter you need to can get it cheaper nowadays on ebay, in decent lengths too.
bezford
PostPosted: Sun Jan 06, 2013 5:36 pm Up
im not sure about this guys idea but as far as the part youve asked about id say its certainly worth a try at that price...im not keen on the blue pipe but the blue ends look ok...it will extend to three feet long so should fit ok...
Send a pic if u go for it...
R.HYDE
dan_manu
PostPosted: Sun Jan 06, 2013 7:03 pm Up
thats what i was thinkin its cheap and they all do the same job so why not , ill jus be careful not to tear it as im fittin it so it should be ok Smile and yeah will do mate
Domo
PostPosted: Sun Jan 06, 2013 7:15 pm Up
how do you fit a cold air feed? and where does it go?
dan_manu
PostPosted: Sun Jan 06, 2013 7:26 pm Up
if uv got a cone filter , you jus channel a pipe from
a cold air supply normaly faceing forward behind the grill of your front bumper and put the other end of the pipe facing into your filter so that it sucks the cold air in, its a lot better for your car and might get u 1 or 2 bhp lol but its also healthier
Quarmbo
PostPosted: Mon Jan 07, 2013 4:39 am Up
Healthier? Very debatable. If it was better for your car, the manufacturers would use it from factory.
Ford SportGay-A
bezford
PostPosted: Mon Jan 07, 2013 6:43 am Up
Not necessarily ...a k&n filter is certainly better than a standard one but they dont fit them...that goes for all performance products and upgrades i dare say...
R.HYDE
dan_manu
PostPosted: Mon Jan 07, 2013 8:15 am Up
by healthier i ment if u were to have a cone filter on your car before you bought it fitting a cold air feeed pipe would make it healthier, im not compareing it to the standard air box and filter
Quarmbo
PostPosted: Mon Jan 07, 2013 9:00 am Up
True, I give you that, but I wasn't talking about a panel filter, nor would I call that a performance upgrade. The guy was talking about a cone filter and a cold air feed, something entirely different.
Ford SportGay-A
jonsully
PostPosted: Mon Jan 07, 2013 12:57 pm Up
i bought that cold air feed before xmas and it seems fine.i didnt go messin about with it too much as the plastic is thin but as a feed that is fitted and left alone it does the job fine
dan_manu
PostPosted: Mon Jan 07, 2013 1:22 pm Up
sound mate, hearin that ill buy once tomorow, was it hard to fit??
