Latest: sparrowdclxvi
Overall: 17139
Online Now [287]:
Visitors: 286
Today: 36002
Total: 112609383
Forums › The Car › 206 Problems › engine swop problems
LORDPSK
PostPosted: Wed Jan 16, 2013 11:59 am Up
The 1.4 engine in my 1999 206 headgasket has gone, so I decided to swop the engine with a 2002 engine that was out of a saxo, the saxo engine was suggested by a fellow member on here.
I swopped all the electrical components, flywheel and clutch assemberly, complete wiring, inlet manifold, exhaust manifold, etc, the only difference was the old engine was the spin on oil filter type and this one has the vertical paper filter type.
Came to connect the exhaust and the position of the lamba sensor is stopping the exhaust connecting onto the manifold as the upright plastic oil filter housing is fouling on the lamba sensor, I am sure this is a problem others have encountered up but I am unable to find any details using the search facility.
I see three solutions,
1. cut the exhaust and turn it 33 degree as it is a three bolt connection and reweld
2. cut the lamba connection out of the exhasut pipe and reweld in new position welding a blank over the old hole.
3. somebody is going to give me a brainwave on how they cured the problem.
Peugeot 206
shadow
PostPosted: Wed Jan 16, 2013 12:25 pm Up
could you not use the front pipe off a saxo then connect to your original exhaust using a flexi pipe
206cc 2.0 allure
PostPosted: Wed Jan 16, 2013 12:27 pm Up
You need to get the exhaust system from a 206 1.4 that has an underfloor cat. I had this problem when I changed the engine in my 1.4
PostPosted: Wed Jan 16, 2013 12:31 pm Up
Can't you just take the original lambda sensor out the downpipe & screw it in to the top of the later manifold instead?
Then block the downpipe hole up - see your motor factor for a blank.
kobrakai1986
PostPosted: Wed Jan 16, 2013 12:34 pm Up
Ive not long scrapped a manifold and cat that would have done the job. I have the same oil filter. You dont necessarily need the underfloor cat manifold as the manifold with the 4 bolt cat will work perfect as that is what was fitted to my 2002 1.4.
'02 206 Quiksilver. SP Kit. Gloss black 205 Speedlines. ICC Tuning WRC spoiler (civic style). Sparco Rally Flaps. Laguna splitter. Upper and lower front Struts. V-Maxx front coilovers and Apex rear shocks. GTI180 front Arb. GTI180 front brake set up. 4-2-1 Mani, 200cell sport cat, stainless pipes and sportex 3" rolled box. Gloss black morettes with yellow lenses. Yellow tinted fogs with yellow bulbs.
LORDPSK
PostPosted: Wed Jan 16, 2013 12:53 pm Up
Thank you for your replies,
Unfortunately I do not have the cownpipe off the saxo donor engine that I bought.
The original exhaust manifold on my car is a three bolt connect and to use a four bolt cpnnection would mean buying either a new exhaust or making a plate connection to marry together
I think that the only option ids to cut and weld
Peugeot 206
