Online Now [151]:
Visitors: 150
Today: 71955
Total: 140065353
Forums › The Car › 206 Talk › MOT test results fail
dan_manu
PostPosted: Thu Jan 17, 2013 6:07 pm Up
not too bad as i can sort these out but its just my emissions im worried about, firstly of all it failed on -
- nearside headlamp aimed too high
- exhaust noise is clearly in excess of that emitted by a similar vehicle fitted with a standard silencer in average condition
-windowscreen sticker (my sunstrip) or other obstruction encroaching by more than 10mm with zone A
-windowscreen sticker or other obstruction encroaching into the swept area by more than 40mm outside zone A
- nearside side repeater incorrect collour
now this is what im worried about and need advice please as i dont understand it, but the mechanic said that my exhaust was so big it was sucking in oxygen !? Embarassed
fast idle test - failed
engine speed 2500 - 3000rpm - not checked
co =< 0.30% 0.52% - fail
hc =< 200ppm 126ppm pass
wierd symbol i can put :S like an upside down 'Y' 0.97 - 1.03 1.048 - fail
second idle test: fail
co =< 0.30% - 0.33% = fail
hc =< 200ppm 91pmm - pass
(upside down Y) - 0.97 - 1.03 1.052 - fail
natural idle test - fail
engine speed 450 - 1500rpm not checked
co =< 0.50% 0.71% fail
advice please? bit of a dragging topic -.-
chinabluegti
PostPosted: Thu Jan 17, 2013 6:11 pm Up
Do you still have the standard box? To get it through the MOT?
1997 106, 2002 206 LX 1.4, 2004 GTHDI,
2008 207 GT, Renault Clio 1.4 Dynamique 2006,
Honda Civic Type R 2004 EP3 Model and a road legal Suzuki LTZ250 Quad Bike Wink
Old Registration Info, Over 2000 Posts
13 Seller Feedbacks
dan_manu
PostPosted: Thu Jan 17, 2013 6:19 pm Up
yeah mate i got the standard back box, do u think this will pass me through the emissions test?
PostPosted: Thu Jan 17, 2013 6:34 pm Up
I don't think the back box will have any effect on the emissions. A good thrashing before the MOT to warn the cat up might help though.
dan_manu
PostPosted: Thu Jan 17, 2013 6:38 pm Up
ahh il try that aswel, i left it for hour hour there in the cold before mot, any else suggestions?
namgaj
PostPosted: Thu Jan 17, 2013 7:01 pm Up
Put some "wynns pre MOT" or "Wynns emmisions reducer" in your fuel tank and give the carr a good hard drive
4.0 V8 S-Type Jaguar
dan_manu
PostPosted: Thu Jan 17, 2013 7:56 pm Up
do you think this will be enough to pass through the mot?
and does this look too cheap? www.ebay.co.uk/itm/WYN...2ebaf6f1fb
iainlovatt
PostPosted: Fri Jan 18, 2013 4:02 am Up
You get much better chemicals to reduce emmissions in SHELL performance petrol, So fill up with that and get the car nice and hot for the re-test.
Part from that its a cheap fix for the car to have another year on the road.
(My Garage)
namgaj
PostPosted: Fri Jan 18, 2013 6:33 pm Up
THATS THE STUFF!!!! Shove some of that in, run it through and watch it pass Cool
Fifer
PostPosted: Sun Jan 20, 2013 6:24 am Up
What he may mean, as I had this before with a blitz system is that when they put the probe up the exhaust it can only reach so far. If the bore is too large then the gasses swirling out can also cause some normal air to enter the exhaust enough to interfere with the testers probe. If you could insert the probe further the problem would go away. But you cant. So reducing the bore size by fitting the old backbox should see it pass.
1.4hdi 02
PostPosted: Sun Jan 20, 2013 7:49 am Up
Or does he mean there is a leak in the exhaust system? Causing on the negative exhaust waves to draw in sed oxygen to throw out your emissions?
Had a bit of a giggle on the fact its too loud, at 107DB i still pass because its a subaru impreza Wink
