Posted: Thu Jan 17, 2013 11:07 am |
Hi my screen wash is not working i topped it up the other day so i know the levels ok but what happens when i use the switch inside the car that makes it work there normal to be a buzzing sound well i am pulling the lever back its not making that sound and just not working wipers and everything else work fine its just the screen wash could it be a fuse or something thanks
Posted: Thu Jan 17, 2013 11:11 am |
Are the jets frozen?
Posted: Thu Jan 17, 2013 11:13 am |
i dont think so the levers just not working for for it for some reason
Posted: Thu Jan 17, 2013 11:18 am |
I would just wait until it warms up a bit before you start doing things, it does sound like its just frozen up.
Posted: Thu Jan 17, 2013 11:23 am |
so i could try whats the fuse number and amp for the screen wash its a 98 1.4 lx cheers
Posted: Thu Jan 17, 2013 11:26 am |
If the motor is making a noise its not the fuse or the stalk.
Posted: Thu Jan 17, 2013 11:29 am |
Big_Rich180 wrote: |
If the motor is making a noise its not the fuse or the stalk. |
Posted: Thu Jan 17, 2013 11:38 am |
sorry think thats what i meant the motors not making a noise when you pull the stalk back lol
Posted: Thu Jan 17, 2013 11:40 am |
Try using some punctuation so people can read what your writing properly then.
Posted: Thu Jan 17, 2013 11:45 am |
Trade Rating: +45
If there is no buzzing check the fuse and if that is all ok it sounds like the pump has had it as I'm sure it should still try and make a noise even if it is frozen ?
| PAST -2008 Vauxhall Astra VXR / 2002 pug 206 GTI
Now have my 106 GTI track car
TEAM - I HATE FACEBOOK | |
Posted: Thu Jan 17, 2013 11:52 am |
Try putting some slightly warm water in in.
Posted: Thu Jan 17, 2013 11:54 am |
It won't make a noise if the bottle and motor is frozen!
Most fuse boards have what the fuse is for either on the lid over the fuses or next to the fuse.
Failing that buy a Haynes manual. Relatively cheap and helpfull for items from basic to advanced.
Posted: Thu Jan 17, 2013 12:05 pm |
ok thanks
Posted: Thu Jan 17, 2013 12:45 pm |
I would look at my manual or car and tell you but both are currently 70 miles away!
Posted: Thu Jan 17, 2013 1:48 pm |
probs just frozen mate
