Posted: Thu Jan 31, 2013 2:11 pm |
I have been looking over the net and cant seem to find the correct rear wheel bearing for my 02 1.4 hdi. My bearing has a tapered style yet most seem to be a straight style. Even euro car parts show a straight one for my reg.
Anybody know where I can get a tapered o
one from
Posted: Thu Jan 31, 2013 3:30 pm |
disc or drum?
Posted: Thu Jan 31, 2013 4:09 pm |
Drum
Posted: Thu Jan 31, 2013 4:12 pm |
we only got 1 type of drum bearing.
Posted: Thu Jan 31, 2013 4:37 pm |
Posted: Thu Jan 31, 2013 4:55 pm |
you are right. even it is taper bearing it can still have a cylinder shape
Posted: Fri Feb 01, 2013 5:45 am |
The shell is still inside the drum. Ideally it needs pressing out, but a hammer and appropriate sized drift can do the job.
There should be a little circlip which holds the bearing in place just below the hub nut and pressure washer. If it's one of the old style, it's a pig to get out.
Posted: Fri Feb 01, 2013 5:55 am |
Thanks guys. Ill drop the hub off and have another look. Cheers
