Posted: Fri Feb 01, 2013 8:22 pm |
Any tips on how to get out?
Posted: Fri Feb 01, 2013 9:25 pm |
tint them - you won't see the condensation - problem solved
Posted: Sat Feb 02, 2013 12:40 am |
Take the lights of the car & either stick them in an airing cuboard or use a hair drier. The problem will probably come back, so might be worth checking the seal between the lights & bodywork.
Posted: Sat Feb 02, 2013 2:50 am |
Trade Rating: +13
Once you have dried them you need to re seal them with silicone sealer. Or buy a ne set that has been pressure tested?
Posted: Sat Feb 02, 2013 5:33 am |
Silicone sealer sounds like a good idea, how much does it go for at a local retailer?
Posted: Sat Feb 02, 2013 7:03 am |
You can get it at any DIY store b&q,home base ect just make sure you get the clear drying stuff shouldn't be much more than £2.50
Posted: Sat Feb 02, 2013 7:50 am |
Trade Rating: +13
spike_202 wrote: |
You can get it at any DIY store b&q,home base ect just make sure you get the clear drying stuff shouldn't be much more than £2.50 |
