Online Now [873]:
Visitors: 873
Today: 236063
Total: 150826075
Forums › The Car › 206 Talk › How much coolant does it hold
Forum Index › 206 Talk
olly
PostPosted: Wed Jan 30, 2013 3:16 pm Up
Hi all,can anyone who has changed the coolant on a 2001 1.4 8v tell me how much it holds,my manual says 7 litres i think it was ?
After flushing rad and engine out to put new coolant in,for some reason my calculations did not add up to 7 litres.I only put 4.25 litres in and the tank is full even after warming engine until fan cuts in,and opening the 2 bleed screws to remove air as filling up.
I ask as i put the water in first then when half full i was going to add the antifreeze,but only managed to get a little of it in,as i need 50/50 ratio. Embarassed
cheers Olly
bcfc
PostPosted: Wed Jan 30, 2013 3:28 pm Up
You can drain as much as possible but you can't drain all the coolant in the engine block.
P6RAF
PostPosted: Wed Jan 30, 2013 3:30 pm Up
As long as you put in roughly what you drained out you can't be far off.
2004 206 HDi GTi, Obsidian Black.
VW Polo 1.3 GL - 205 GTI 1.6 - 306 D-Turbo - First 205 GTI 1.9 track car - Second 205 GTI 1.9 Track car - 106 XLD - Impreza WRX - 406 V6 - 206 HDi GTi
PostPosted: Wed Jan 30, 2013 4:34 pm Up
always make the coolant+water mixture before,then add it,so no matter how much car takes,it will be 50/50 ration as you mixed it before adding,but still there will be water inside the engine block,and the heater matrix inside the dash,so you will add about 4-5 liters
olly
PostPosted: Thu Jan 31, 2013 3:53 am Up
Looks like I will be draining it all out again then,think because I flushed the rad and engine out I had removed it all,but thinking what you said there's no way it can all come out the block and heater. Cheers all
bcfc
PostPosted: Thu Jan 31, 2013 7:40 am Up
You dont need to take it all out, just drain a litre of two out and top it up. Does your radiator have a drain screw?
olly
PostPosted: Fri Feb 01, 2013 3:51 pm Up
I just took the bottom hose off the rad and put roughly 4 litres back in it.
bcfc
