Latest: sparrowdclxvi
Overall: 17139
Online Now [497]:
Visitors: 496
Today: 39455
Total: 112723439
Forums › The Car › 206 Talk › Need a Good French car specialist
joe1983
PostPosted: Sat Feb 02, 2013 5:28 am Up
Im after a good French car specialist in the midlands area to fit my clutch in my gti180. any recommendations guys?
broadblaster
PostPosted: Sat Feb 02, 2013 5:34 am Up
and where is your area ???
on a back road playing
joe1983
PostPosted: Sat Feb 02, 2013 5:35 am Up
Staffordshire
broadblaster
PostPosted: Sat Feb 02, 2013 5:38 am Up
lol i see you have alterd your first post bit out of my area mate so sorry no i don't but i'm sure somebody on here will be along soon with a person near you who can do it.
joe1983
PostPosted: Sat Feb 02, 2013 5:42 am Up
Yes ive just put my location on my profile just. Thanks for the help anyway.
broadblaster
PostPosted: Sat Feb 02, 2013 5:46 am Up
no probs mate tbh its not that bad a job to do just make sure you fit a new input shaft seal/bearing at the same time, also worth changeing the driveshaft seals while your at it.
has your got the dreaded judder ???
PostPosted: Sat Feb 02, 2013 6:23 am Up
You really don't need a French car specialist to fit a clutch on a 180. Any independent garage should be capable of doing what is a straight forward job.
Andy180
PostPosted: Sat Feb 02, 2013 7:02 am Up
Abp motorsport in crewe are alright
GTI 180
joe1983
PostPosted: Sat Feb 02, 2013 9:31 am Up
Yes been there a few times when i had my saxo vts and 106 gti.There labour prices are a bit too high for me.
Andy180
PostPosted: Sat Feb 02, 2013 9:42 am Up
Birchdown is quite well regarded on clio sport and they were pretty reasonable when I had a quote for a cambelt change might be worth asking them for a quote, there near whitchurch
GTI 180
joe1983
PostPosted: Sun Feb 03, 2013 3:54 am Up
Yes they are good,they did work on my clio 182 few years back,but i thought they were clio specialists only?
Andy180
PostPosted: Sun Feb 03, 2013 4:03 am Up
They were willing to do the cambelt on my 180 so I recon they would do your clutch
GTI 180
joe1983
PostPosted: Sun Feb 03, 2013 4:23 am Up
Cheers andy i will give them a call.
