Latest: elelectricistadeMateo
Overall: 17127
Online Now [58]:
Visitors: 57
Today: 21696
Total: 100394374
Forums › The Car › 206 Problems › No air from heaters or air con
peugeot2201
PostPosted: Mon Feb 04, 2013 3:29 pm Up
Hi ive got a major problem with my heating, it was previously working all fine and it all of a sudden stopped working? the car is a 1.6xsi with air con. I have replaced the resistor, checked and replaced the 40A fuse but still don't have any air coming through? on the control panel the rear heated window button works fine but nothing else will work?
thanks in advance.
PostPosted: Tue Feb 05, 2013 12:35 pm Up
Is the heater fan that blows the hot air out of the heater vents actually running and blowing air (even if that is cold) or is the fan itself no longer rotating and blowing air out of the vents? NOTE: I do mean the vent fan and NOT the one in the engine bay in front of the engine.
What temperature is showing on the temperature gauge?
Is the top hose of the radiator getting hot?
Your description is just a little open to different interpretations. Answer the above questions and we can focus our attention.
