Latest: lio94
Overall: 17181
Online Now [101]:
Visitors: 100
Today: 101579
Total: 140447213
Forums › The Car › 206 Talk › left wing
left wing
Simmo
PostPosted: Wed Feb 06, 2013 3:12 pm Up
Does anyone know how to remove a wing? is there a topic on this anywhere? cheers
1.1 silver style www.206info.co.uk/Foru...52484.html
P6RAF
PostPosted: Wed Feb 06, 2013 3:22 pm Up
This any use...
1. remove bolt at the top which is visible when the front door is open
2. open bonnet and remove all wing bolts here, 5 or 6 of them, dead easy.
3. remove bolt at bottom of wing on outside of car, under the sill near where the front jacking point is,
4. remove grille, headlight, indicator and side repeater and unbolt the 2 bolts holding the arch liner at the side of the front bumper. pull it free a bit,
5. jack car up, or put it on axle stands. remove wheel if you want, then remove the 2 bumper bolts holding the bumper on at the sides, (these are really the only difficult bit.)
6. pull the bumper free at the sides a bit to gain access to the last wing bolt.
Wink
2004 206 HDi GTi, Obsidian Black.
VW Polo 1.3 GL - 205 GTI 1.6 - 306 D-Turbo - First 205 GTI 1.9 track car - Second 205 GTI 1.9 Track car - 106 XLD - Impreza WRX - 406 V6 - 206 HDi GTi
PostPosted: Wed Feb 06, 2013 3:23 pm Up
4 bolts if I remember correctly, 2 underneath where the bonnet sits over the edge of the wing, 1 behind the headlight which also holds the front bumper up and then one inside the wing not far from the side indicator.
Simmo
PostPosted: Wed Feb 06, 2013 3:28 pm Up
Cheers guys, appreciate your help i shortly after found this www.peugeot206cc.co.uk...ag0jf3.htm looks dead simple Smile
PostPosted: Wed Feb 06, 2013 3:30 pm Up
Wings can be changed without the need to remove the headlamp IF you have the correct tools Wink
Simmo
PostPosted: Wed Feb 06, 2013 4:34 pm Up
My car is in bits anyway, was in a crash the other day so taken radiator, electric fan, lights and bumper are all off
