Posted: Sat Feb 09, 2013 12:57 pm |
What tools do i need for doing code reading on my 2006 206 stationwagon?
Posted: Sat Feb 09, 2013 1:48 pm |
Peugeot planet, not just the software, but the correct lead as well,
or an E-OBD reader.
Posted: Sat Feb 09, 2013 1:52 pm |
I just bought an Autel Maxiscan MS509 from Amazon for £38. It's not the latest scanner but works fine on the 206 and my Jetta. Shows fault codes, descriptions...live data too. Can't moan for that price.
Posted: Sun Feb 10, 2013 6:40 am |
Thanks for your replys. Do you have to use a laptop or can you get one thats a all in one unit?
Posted: Sun Feb 10, 2013 8:20 am |
Peugeot planet needs a computer running XP to operate it. Diagbox, which is the new PP program can be run on Vista or 7 if you can find either a genuine copy of the software or a crack that works.
EOBD readers can be either PC based software with cable or a handheld AIO unit.
All the above are available on selling sites. Probably from £5 upwards.
A decent accessory shop would usually be able to order EOBD readers in if you ask them.
Posted: Mon Feb 11, 2013 7:32 am |
Excellent thanks for your reply you know your stuff!
