Latest: Andyblue64
Overall: 17123
Online Now [347]:
Visitors: 346
Today: 28900
Total: 98058297
Forums › The Car › 206 Talk › airbag bang or no bang?
lottley93
PostPosted: Tue Feb 12, 2013 11:54 am Up
simple question, see pic. do i just pull out the orange plug to remove airbag or will i end up with a sore nose? if so then what do i do?
been stood there holding it about to pull it out but kept scaring myself and pussied out Very Happy
battery is properly disconnected following BSI shut down thingy.
tarrr muchly Smile
Tolkienfan001
PostPosted: Tue Feb 12, 2013 12:12 pm Up
Trade Rating: +13
If the battery is off surely it can't go off? No power! No bang?
2005 1.4 16v Sport
Check out my 206 here!
PostPosted: Tue Feb 12, 2013 12:31 pm Up
Set your phone to record and pull the plug. If it goes off, you make £250 from Harry Hill and give us all a laugh, if it doesn't then that's just boring. Laughing
After disconnecting the battery, all the power to the airbags should have dissipated after about 20 minutes, making them safe to work on.
It's the sudden power surge the airbags get when you re-connect the battery that you have to worry about Wink
PostPosted: Tue Feb 12, 2013 4:54 pm Up
It's OK.
(famous last words)
No it's OK as long as the batt is disconnected and you leave it alone for a while as macca says.
Wayneone
PostPosted: Wed Feb 13, 2013 8:26 am Up
Pull it!
devotedsniper
PostPosted: Wed Feb 13, 2013 9:11 am Up
You just pull it (i'd have battery off), well i say pull but i popped it off with a flathead. Either way unless you somehow short it it won't go off.
Now a 2010 Renault Megane Coupe owner
lottley93
PostPosted: Wed Feb 13, 2013 11:15 am Up
manned up and popped it off with a very long flathead from a distance whilst looking the other way! safe to say i am still allive Smile next problem is i've lent out my T30 to icannotrememberwho, so all a bit pointless for the time being Very Happy
thanks all though.
