Posted: Wed Feb 13, 2013 6:59 am |
I'm getting a whinning noise when I accelerate in every gear. Starting to think if it is something serious like the gear box, clutch or something, it definatly sounds like a transmittion whine.
What could it possibly be??
Posted: Wed Feb 13, 2013 8:29 am |
So does it go away if you coast with the clutch pressed?
Posted: Thu Feb 14, 2013 4:43 am |
Yes it goes away when you press the clutch in
Posted: Thu Feb 14, 2013 5:02 am |
I had the same problem, but I found, when the wife is not in the car there is no whining at all when I accelerate.
Posted: Fri Feb 15, 2013 11:22 am |
haha, just need to know really because I've just had the car and it has 3 months warrenty so need an idea so i can get it fixed.
Posted: Thu Feb 21, 2013 12:33 pm |
Ive got the same problem on my 206 1.4 lx, any info would be helpful !, someone told me it could be something to do with the gearbox but it still makes the noise in neutral
Posted: Fri Feb 22, 2013 3:50 am |
Thrust bearing?
Posted: Fri Feb 22, 2013 4:15 pm |
I would say its the gear box.
Posted: Sat Feb 23, 2013 3:50 am |
99% gearbox. Get it replaced or full refund under warranty.
