Posted: Tue Feb 19, 2013 11:48 am |
hi.
i have looked through the forums and have sort of found the answer i require but am little bit unsure.
these morettes have already been wired up - from another that was scrapped - but i am still unsure wether my car requires the same wiring.
in both pictures there is a yellow wire that from what i read has to be grounded.The bigger arrow shows a longer wire that i belive shoud go to the battery ( with in line fuse ofc ).
my car is a multiplexed (2002), so is it still right or do i not require the relay that has already been wired up?
Also if i still need to wire to battery , what amp fuse should i use?
many thanks
Posted: Tue Feb 19, 2013 11:50 am |
Top one is an earth! So attach it to chassis of car!
Bottom one need end cutting off it and connecting to power. Ie battery!(long wire) There is also a cable that need earthing on the bottom one too!
Posted: Tue Feb 19, 2013 11:54 am |
wouldnt bother putting fuse in! More hassle than its worth imo! They are fused anyway on car circuit.
You still need to wire them up even though your car is 2002. Earth each light, and attach the passenger one with the long wire to the battery, then plug and pay with rest of wires and you are away!!
Posted: Tue Feb 19, 2013 11:55 am |
thanks bud
any idea what fuse i should inline to the battery?
ty
Posted: Tue Feb 19, 2013 11:56 am |
ahh ok - replied too soon lol
no fuse ,ty
Posted: Tue Feb 19, 2013 2:31 pm |
Posted: Tue Feb 19, 2013 6:02 pm |
Thats great
thanks DJ-
