Posted: Wed Feb 20, 2013 9:37 am |
Posted: Wed Feb 20, 2013 9:55 am |
Is that the sump end of the oil filter attachment?
There's a couple of O ring seals located behind there.
Posted: Wed Feb 20, 2013 11:08 am |
My leaks too i replaced the rocker cover gasket cured the top leak but bottom leak was still there. On replacing the timing belt saw the camshaft oil seal was leaking slightly , so replaced that.
Mine is still leaking so i need to take cambelt back off and replace the crankshaft oil seal too.
If yours is leaking drivers side bottom, good chance it could be these seals too.
Posted: Tue Mar 12, 2013 3:21 pm |
snap - our 2005 1.4 16v is leaking just the same, worse in the cold weather.
its in the garage tomorrow having the crankshaft seal changed (along with timing belt).
Posted: Fri Mar 15, 2013 1:50 pm |
| black206 wrote: |
its in the garage tomorrow having the crankshaft seal changed (along with timing belt). |
its not the crankshaft.... but the head leaking oil externally. Seems to be a common thing with the gasket failing from looking on the net.
| Black 2005 206 sport 1.4 16v | |
Posted: Wed Apr 24, 2013 4:43 pm |
hi guys mind if i butt in? mine is leaking too, it's a 2004 1.4 diesel. the leak seem to be from the back of the engine, above the starter but i can't bloody see for sure. it is leaking out on bolth sides underneath the car? any ideas??? ta
ps what milage should the belt be done??
