Latest: DanDan17
Overall: 17128
Online Now [64]:
Visitors: 63
Today: 31251
Total: 100551144
Forums › The Car › 206 Talk › poxy blower motor
poxy blower motor
sx206
PostPosted: Fri Feb 22, 2013 1:06 pm Up
is it possible to wire the blower motor off the battery and use a toggle switch.
car is muliplexed if that makes any odds.im freezing my nads off at the moment,any help would be appreciated. Crying or Very sad
206
PostPosted: Fri Feb 22, 2013 1:14 pm Up
Instead of BODGING, why don't you diagnose & fix the fault with the help of the forum.
sx206
PostPosted: Fri Feb 22, 2013 1:27 pm Up
having bought new motor,checked all fuses plus relay,i think my problem is short somewhere behind dash,not got time to investigate at the moment mr bsi,so if i can quickly wire straight off the battery for a few weeks it would do me for now.thanks for your input any way.
206
HDI90
PostPosted: Fri Feb 22, 2013 2:49 pm Up
Done this on my old peugeot expert van , just wired a inline switch from a live . But the speed will be all or nothing
GTI 180
sx206
PostPosted: Fri Feb 22, 2013 3:07 pm Up
thanks for that mate,right now full blast would be luxury.will give it a go tomorrow,thanks again.
206
devotedsniper
PostPosted: Sun Feb 24, 2013 4:24 pm Up
I assume your fan is either doing nothing or only certain ones work? Probably the Heater Resistor, had to change the one on my 307 this week and it was a pig of a job for me (pulled it down and 2 of the wires were brittle and snapped). But like the others said it can be done but it will only be on/off, the 307 guide i used even tells you to test the fan with a battery charger (http://www.peugeotforums.com/forums/307-38/how-fix-broken-heater-blower-307-a-13429/).
Now a 2010 Renault Megane Coupe owner
