Latest: heikkisj
Overall: 17126
Online Now [64]:
Visitors: 63
Today: 469
Total: 100309903
Forums › The Car › 206 Problems › Vibration from gear box
Thinkyourboss
PostPosted: Thu Mar 14, 2013 7:25 pm Up
I have a 2002 peugeot 206 1.4 petrol , manual, when accelerating there is a on off pulsing vibration "1 second intervals" this only happens when accelerating and maintaining the same speed, the vibration can be felt through the pedals and slightly through the steering wheel, this happens in every gear apart from 1st and feels like its coming from the gearbox.
The pulsing vibration seems to be worse as certain revs, it is predominately there around 2500 revs, any ideas?
ryanovsalford
PostPosted: Fri Mar 15, 2013 4:38 am Up
could be an engine/gearbox mount is it an aggressive vibration
ryanovsalford
PostPosted: Fri Mar 15, 2013 4:40 am Up
its a long shot also but even a buckled wheel can cause i vibration throught the steering wheel or worn suspension components
Thinkyourboss
PostPosted: Fri Mar 15, 2013 4:52 am Up
It seems quite aggressive when i am going about 50mph, once i am going over 50 its just a slight vibration/humming, i was thinking it was the transmission as its coming from there, i will have a look at the mounts
ryanovsalford
PostPosted: Fri Mar 15, 2013 5:42 am Up
i had the same problem it sounds like a very worn wishbone but get a garage to check it first
DREWDEN
PostPosted: Fri Mar 15, 2013 8:08 am Up
Check gearbox oil, Could also be gearbox bearings.
206 2ltr Hdi glx 53 plate
