Forums › The Car › 206 Problems › Potential gearbox issue? Unsure.. |
Posted: Sun Mar 03, 2013 2:07 pm |
Basically when driving and the revs get to around 2k you can hear a sort of wirring/droning noise, kinda sounds like a noisy wheel bearing. But then once you get to around 3k it goes away. the noise also disappears when you let off the accelerator, put the clut.ch in or take it out of gear. But increases if you put your foot down around the 2,000 revs region. Anyone shed light on this? Ive sta
rted to notice it more recently but that may be because ive gone back to a standard exhaust (however you could still here it before). It wouldnt be so bad but i tend to sit at around 2k on a daily basis on the way to work and back.
The car is a 53 xsi with 55,000 miles
| 1.6 Xsi - Work in Progress!
"If it has wheels or a skirt, it's gonna give you problems." | |
Posted: Mon Mar 04, 2013 2:13 am |
Anyone?
