Latest: lio94
Overall: 17181
Online Now [88]:
Visitors: 87
Today: 6652
Total: 141257416
Forums › The Car › 206 Talk › courtesy bulb
courtesy bulb
Simmo
PostPosted: Mon Feb 25, 2013 2:31 pm Up
So i thought id be all flash buying a cheap LED bulb from eBay to make my courtesy bulb much brighter. I have just installed it and it does not work, i rotated 180 degrees as it says if it does not work to do so and it also says to check if my car has a bulb failure computer. Is the bulb just faulty? do 206's have a bulb failure computer? has anyone else tried this?
1.1 silver style www.206info.co.uk/Foru...52484.html
PostPosted: Mon Feb 25, 2013 2:52 pm Up
I don't think any 206 has a bulb failure warning system
Try it in the boot or sidelights, they all take 501s. If it still doesn't work, then it's a dud bulb.
mtempsch
PostPosted: Mon Feb 25, 2013 2:58 pm Up
Nope, no bulb failure computer.
Easiest way to check is probably to apply some temporary wires to test it directly on the battery poles.
One direction or the other should work if the LED bulb itself isn't broken (which is a possibility, broken wire or solder connection) - as a sanity check, the incandescent bulb still works, so you haven't blown a fuse..?
If you want brightness, look at the SMD LED panels...
Silvermetallic 2004 206 RC
Simmo
PostPosted: Mon Feb 25, 2013 3:02 pm Up
Thanks for the responses, ill try the bulb in another socket on the car, see if it lights up elsewhere. Cheers
PostPosted: Mon Feb 25, 2013 4:31 pm Up
i had the same issue, paid £2 on ebay for 501 led bulbs and my interior light wouldn't work, i kept at it and finally got it to work just by moving the bulb around in the holder
Simmo
PostPosted: Mon Feb 25, 2013 4:37 pm Up
Yeah the annoying thing is that you have to keep putting the cover back on and off. I tried for about 5 mins wiggling it about and still nothing. Ill try again tomorrow
Simmo
PostPosted: Tue Feb 26, 2013 5:44 pm Up
I have tried it in my side light socket tonight and it worked but it never in the courtesy light socket. Any ideas?
PostPosted: Tue Feb 26, 2013 6:02 pm Up
Try another bulb in the courtesy light or check it with a multimeter.
Might sound daft, but you have moved the switch to permanently on or opened the door with the engine running to make sure the car hasn't gone into eco mode.
Simmo
PostPosted: Wed Feb 27, 2013 11:47 am Up
Cheers, will try again after work tonight. Fiddled with it so much now that I've crack the courtesy light casing.
Ash
PostPosted: Thu Feb 28, 2013 2:11 pm Up
Have you blown the fuse messing around with it?
