Online Now [817]:
Visitors: 816
Today: 199520
Total: 150501649
Forums › The Car › 206 Problems › Rear Shocks Replace or not?
A10PSW
PostPosted: Thu Mar 07, 2013 10:54 am Up
Now that I have got my Axle off (bearings have gone) should I replace the REAR Shocks.
I fully retracted them both and one has not come back up at all and the other took about 30mins to come up.
Should they come up straight away?
They have been on the car for 7 years.
AX-Rated
PostPosted: Thu Mar 07, 2013 11:36 am Up
Shocks dont return anyway.
Way I see it, if the car isn't bouncing around like the MR SOFT advert, leave 'em.
Black 03 GTi
PostPosted: Thu Mar 07, 2013 3:18 pm Up
Oil dampers don't expand themselves. Gas dampers normally do.
A10PSW
PostPosted: Thu Mar 07, 2013 3:28 pm Up
So they should be ok to put back on?
PostPosted: Thu Mar 07, 2013 3:36 pm Up
Yes.
RossC413
PostPosted: Thu Mar 07, 2013 3:40 pm Up
they are fine to use again, personly id just replace them seeing they are off the car.
i drive a french car yes, they all said it would brake down, it did Sad
A10PSW
PostPosted: Thu Mar 07, 2013 3:51 pm Up
I would normally, but just recently I have had to pay for new clutch, gearbox input bearing, and now a Axle! It would have been cheaper to buy a new car, so now I'm skint!
And the wife want a holiday abroad!!!!!
SinfulDesignCom
PostPosted: Thu Mar 07, 2013 8:40 pm Up
Its a 10 minute job even when they are on the car, so I wouldn't worry at all that you have the axle off...
Replace as and when...
Sinful Design - web design, graphic design, web apps, hosting...
My 2003 GTi 180 Track Project Thread
