Posted: Mon Mar 11, 2013 3:52 am |
been looking at getting all the parts needed seperate as the kits are ober 80 quid
seen this website which is cheap enough
which cable will be good for the 206 im thinking the 170 amp
clicky
| | ![](images/spacer.gif) |
Posted: Mon Mar 11, 2013 4:07 am |
0 Gauge/4 Gauge wire should be fine. Car Audio shops will sell it. I think the cranking amps on a 206 is under 100A even for the diesel though may be wrong.
Posted: Mon Mar 11, 2013 6:55 am |
the wire on that site is cheaper than amp wire i think an at 110 amp red with 15 quid aint gonna break the bank, what about fusing it?
tempting to use the 4 gauge amp wire i got already in there
Posted: Tue Mar 12, 2013 3:37 pm |
I wouldnt go close to the amp rating i'd go above it.
Try your local welding supplies shop. Many people i know, including myself have used welder cable, highly sheilded and very flexible. Amp rating is probably through the roof and the price would be a lot less!
Posted: Tue Mar 12, 2013 4:34 pm |
0 gauge is a complete overkill and dangerous if not fused correctly
4 gauge may be fine, but I've used 2 just to be sure.
Posted: Mon May 27, 2013 11:27 am |
i got some 25mm welding cable 200amps for 24 quid posted so not too bad, was hoping for cheaper but i got it now and plenty left for making a new earth
next problem is where to put it boot or rear footwell and does it have to have a circuit breaker
