Latest: DanDan17
Overall: 17128
Online Now [146]:
Visitors: 144
Members: 1
Today: 16200
Total: 100616619
Forums › The Car › 206 Problems › Connected jump leads the wrong way round - I have nothing !!
SinfulDesignCom
PostPosted: Thu Mar 07, 2013 3:09 pm Up
Please dont judge me!!
I foolishly put jump leads on the wrong way round and now nothing is happening. It is my 180 so there is no help at all with manuals etc.. So far I have tried...
Checking all fuses - as best I can in the dark
Check earth strap
Tried jumping directly to the terminals (bypassing the battery)
It is like something like a fuse has tripped but I cannot see where. I think it is odd that nothing blew.. unless I am missing something. I know of the fuse boxes adjacent to the battery and the one by the steering column, and I can see nothing wrong...
What am I missing??
Sinful Design - web design, graphic design, web apps, hosting...
My 2003 GTi 180 Track Project Thread
Uz
PostPosted: Thu Mar 07, 2013 3:14 pm Up
I'm thinking it's a possible fried BSI unit.
SinfulDesignCom
PostPosted: Thu Mar 07, 2013 3:16 pm Up
Any way of testing/knowing?? Surely I would have SOMETHING, even interior lights?
The battery was completely flat... so I was hoping that the charge didnt get so far
SinfulDesignCom
PostPosted: Thu Mar 07, 2013 3:17 pm Up
would this have tripped and thus need resetting??
RossC413
PostPosted: Thu Mar 07, 2013 3:18 pm Up
fried battery i think take it off try charge it, if it dont hold a charge battery is dead, how long you leave the jump leads on for?
i drive a french car yes, they all said it would brake down, it did Sad
SinfulDesignCom
PostPosted: Thu Mar 07, 2013 3:19 pm Up
They were on for maybe 30 seconds before starting the donor car... then when it didnt start, I immediately saw fault and disconnected
I am charging battery now - but surely jumping direct to terminals would at least work??
Thanks guys.. I'm really worried for my baby here!!
RossC413
PostPosted: Thu Mar 07, 2013 3:21 pm Up
think youll just have to wait and see.
SinfulDesignCom
Neutral
RossC413
PostPosted: Thu Mar 07, 2013 3:24 pm Up
SinfulDesignCom wrote:
i know waiting is a pain, if you have another battery try it?
SinfulDesignCom
PostPosted: Thu Mar 07, 2013 3:32 pm Up
only a jap battery with wrong terminals... cant even stretch the charger to the car to do it that way...
Uz
PostPosted: Thu Mar 07, 2013 3:37 pm Up
It wouldn't matter if it's a fried battery because your not getting anything even if you go directly to the terminals themselves. I'm not sure how you test the BSI...but there is a few threads about on here which will tell you.
SinfulDesignCom
PostPosted: Thu Mar 07, 2013 3:40 pm Up
I am thinking more along the lines of... cheap jump leads... 30 seconds on inverted polarity.. possibly fried jump leads...??
Don't know - just want to be able to sleep tonight!! Smile
PostPosted: Thu Mar 07, 2013 4:00 pm Up
My Thoughts also.
PostPosted: Thu Mar 07, 2013 4:29 pm Up
had a few customers at work do this. ecu/bsi is normally ok because there are so many circuit protections not sure where off the top of my head but most cars have a main bolt in fuse like 100amp or something to protect against this. it wont be in the fuse box with the blade fuses will be either tucked away under the dash or underneath the main fuse box or something like that. il have a quick look on our data at work tommorow and see if they have got one and if so where it is.
PostPosted: Thu Mar 07, 2013 4:52 pm Up
Maxi fuses under the fuses in the engine compartment. I'd check those too. but you have put a live where it shouldn't, so who knows what problems there might be.
Someone else did this not long ago, so do a quick search. He didn't have many problems tbh.
