Posted: Wed Mar 06, 2013 4:25 pm |
allright lads i currently got my 180 with a xenon conversion and was wondering if the standard bulbs (non xenon) are the h4 ones. if i get pulled by the police then atleast i can quickly change them, is it a 3pin connector because i seen that while changing the sidebulbs,
thanks and p.s its an 05 plate
Posted: Wed Mar 06, 2013 4:27 pm |
h7
Posted: Wed Mar 06, 2013 4:29 pm |
well why is there a 3 pin connector?
Posted: Wed Mar 06, 2013 5:23 pm |
What headlights has it got? Standard crystals should have h7 bulbs. Also, just because you can change a bulb roadside, isn't going to stop you getting points or fined.
Posted: Thu Mar 07, 2013 12:34 am |
| gtijames22 wrote: |
| well why is there a 3 pin connector? |
The bulb type should the readable molded into the plastic at the top of the housing.
The plug that connects to the housing is 3 pin because it carries +12V for dipped beam, +12V for full beam, and common ground.
Inside the housing it splits into 2x 2-pin plugs with +12V and ground for respective bulb.
2x
There is no 'H4-style' 3-pin connector (at least in my wiring loom) that can plug onto an H4 bulb.
Functionally it also differs in that for a H4 bulb only one of the 12V feeds is active at a time (i.e. either full or dipped is on, never both) while on the dual H7 bulb setup, dipped beam remains on together with the full beam.
| Silvermetallic 2004 206 RC | |
Posted: Thu Mar 07, 2013 12:55 pm |
cheers lads, well i only gave it a quick glance, i didnt think it was a h4, yeah they are standard crystals.
Posted: Thu Mar 07, 2013 1:27 pm |
"Sorry officer, I'm just going to get my illegal lights out and get the normal ones I purposely left in the boot for when you pull me. Obviously, you don't have to fine me now. And I promise I won't change them back after. Honestly"
Deserve to be caught and fined
Posted: Thu Mar 07, 2013 1:41 pm |
| Ash wrote: |
Deserve to be caught and fined  |
lol i meant change them at home an sell the kit, whats up with u, someone stole your pokemon cards?
Posted: Thu Mar 07, 2013 1:46 pm |
| gtijames22 wrote: |
| Ash wrote: |
lol i meant change them at home an sell the kit, whats up with u, someone stole your pokemon cards? |
Ohh then my apologies
Posted: Thu Mar 07, 2013 1:48 pm |
no probz lol
