Online Now [914]:
Visitors: 914
Today: 144545
Total: 152542510
Forums › The Car › 206 Problems › Central locking not working on 2 doors??
gsc1ugs
PostPosted: Thu Feb 28, 2013 8:21 am Up
Hi
I had a smashed door and replaced it from a scrapper car, when i unplugged the door loom, i heard the other doors lock, I replaced everything, even used my original loom and now the key only locks and unlocks the new passenger door? boot and drivers door no response..
car is 55 plate 206.. any information would be appreciated, i've checked fuses, cant see any blown
LORDPSK
PostPosted: Thu Feb 28, 2013 10:32 am Up
is the interior light going on and off when the door is opened and closed
Peugeot 206
gsc1ugs
PostPosted: Thu Feb 28, 2013 10:44 am Up
I havent checked, what would it be if it is?
LORDPSK
PostPosted: Thu Feb 28, 2013 11:14 am Up
the interior light switch and lock motor are all one, I have simliar problem, checked light and light was not coming on when door was opened, changed combined lock/motor and all worked ok. If you do have to do it check wiring and plug type and there are a few different types out there.
Peugeot 206
gsc1ugs
PostPosted: Thu Feb 28, 2013 11:44 am Up
Well, i changed the door and replace that used door loom with my original because all the fittings are the same
PostPosted: Thu Feb 28, 2013 11:46 am Up
Fit your original lock motor to the replacement door.
I get the feeling one of the lock motors is the wrong type for the car.
Mixing normal central locking & deadlocking motors together = odd faults with the central locking system.
gsc1ugs
PostPosted: Thu Feb 28, 2013 11:49 am Up
Right, i plugged my original in, didnt fit in in the door but left it dangling, problem still there
PostPosted: Thu Feb 28, 2013 11:51 am Up
Did you shut the catch part of the lock thats dangling so it thinks the door is shut before operating the central locking?
gsc1ugs
PostPosted: Thu Feb 28, 2013 12:20 pm Up
Noni didnt, i'll try that thxs, so for now, check interior lihhts flashing and plug in orig lock and close latch, keep u posted
gsc1ugs
PostPosted: Fri Mar 01, 2013 5:12 am Up
Ok, update
1St - the lights inside are not flashing, 2nd the original lock fitted and still other 2 doors do not respond.
gsc1ugs
PostPosted: Fri Mar 01, 2013 5:15 am Up
Yes the interior light works has it should, light is on unlocked then when i click keyfob, locks the passenger door only and light fades off has it should, its just the drivers door and tailgate not responding since i changed the door
PostPosted: Fri Mar 01, 2013 8:49 am Up
Reboot the BSI unit, its odd this fault has only happened since you have replaced the door.
gsc1ugs
PostPosted: Fri Mar 01, 2013 9:33 am Up
How do i reboot the BSI?
gsc1ugs
PostPosted: Fri Mar 01, 2013 1:44 pm Up
Is this it?
1. Start the car and then turn off the engine
2. Pop the bonnet and put the drivers window down and lock all the doors (from the outside)
3. Wait 3 minutes (the bsi needs time to shut down)
4. Take off the battery terminal and wait for 15-20 seconds, then re-attatch it.
5. Lean through the drivers window and turn on the side lights (DONT OPEN THE DOORS)
6. Put key in and turn the ignition on, but not the engine
7. Hold button on key for 10 seconds.
8. Turn ignition off and try the doors - they should now work
9. Turn the engine on and off so the bsi saves the changes
tried it, didnot work...
55 plate 206, open and shut keyfob just for clarification
gsc1ugs
PostPosted: Sat Mar 02, 2013 3:50 am Up
Again for clarification, the key in the drivers side door, when manually locking does lock the passenger door aswell, but not the boot, i cant hear drivers door or boot lock operating
